ORIGINAL: seanrolsen
Oh...
About the stock transmitter on the HB2 - Does the Trainer switch do anything, and what exactly does the 3D switch do? It looks like from the movies I have seen, if you perform a roll, then flip the switch, the main rotor pushes instead of pulling, allowing you to fly upside down. If I flip the switch when I am hovering, will it slam against the floor??
Thanks!
I con't find the trainer switch actually doing anything for the heli... probably for the trainer cable or something... as for the 3D, it adjusts the pitch so that it can fly upside down, I don't know for sure but I think if you were however and flipped it, it would fly straight towards the ground, that is however only going on the fact that when i flip it on the ground the heli is like stuck to the ground... I've never tried to flip the switch while hovering... not sure i really want to...
