RCU Forums - View Single Post - Ryobi and CH
Thread: Ryobi and CH
Old 04-22-2005 | 10:46 AM
DCFLYYER
Default Ryobi and CH
Started a Ryobi conversion and did not like the clearance between the flywheel and the cowl
Not to mention it would be a little to nose heavy. Well I finally picked up a CH. ignition
I originally had a Wacker eng. prop hub on it. I need to keep the same distance from engine to end of prop hub I had with the flywheel installed
Now I need to mount the earth magnet.
I guess what I need to know is do I buy a timing wheel, or do I cut out the center of the flywheel (don’t even know if that would work) Does anyone make one to match the bevel of the crank and key way(1/16)?
The instructions talk about a timing plate and setscrew but is not clear to me.
Can you help?
Dennis
