RCU Forums - View Single Post - DPM airplanes
Old 04-22-2005 | 04:19 PM
greyhound man's Avatar
greyhound man
Default RE: DPM airplanes
with a moki 2.10 on the dpm edge the vertical is unlimited. im still breaking in the moki and it definitely has more than enough power, only about 2 gallons through it so far. If you use a 2.10 put everything as far back as possible in the fuse and it should be close to the right cg.
