When using ABS tires, or PVC tires you're going to want as much traction as possible, so going for less traction is not a good idea. However, if you're using some rubber tires it probably wouldn't be a bad idea. I think people have tried one-way's front/rear/front and rear and said it worked. If you've got the parts laying around give it a try, what do you have to lose except an hour or two of tinkering.
