go for a short walk with your Rx, a couple of servos, Rx battery and the Tx. about 100yrds should do it, then give it a test.
I suggest this because alot of houses create all sorts of RF noise making servos "chatter a bit"
for instance i can't setup any of my stuff on 35.020Mhz (UK freq) due to the servos moving about too much, but at the flying site it's fine
Just be sure to do a range check of some sort at the field and you should be fine
Excuse me if my post doesn't fully make sense, but it's just gone 2am and i need sleep
