How much battery do I need?
I am building an Aeroworks 36% Katana. I will be using the following servos
Elevator two (2) 5945s on a 50" long extension
Ailerons four (4) 5945s each side is on its own channel with a Y on each side 24" extension to the inner servo and a 48" extension to the outer servo, on each side.
Rudder one (1) 5955 on a 12" extension.
Throttle one (1) 5475 on a 12" extension.
Choke one (1) 422 on a 12" extension.
all extensions are 20 gauge wire.
I will be running this through an I4c power isolator. I was planning on powering the servos with two (2) 2100 mAh 5 cell AA size NiMH packs, will this be enough power or should I get larger packs?
Stephen
