ORIGINAL: MerlinL14
On the bottom. The lower surfaces produce the higher air pressure so you seal that surface.
Huh???
Regardless of where the pressure is, you only need to seal one side to seal it, right? (If one side is sealed, then the gap is sealed and air can't slip through it)
Put it on the bottom so it's hidden.
