RE: RC10GT Engine Starting Question- HELP!
Hi
Here is a little trick that I use on my RC10GT. Take a paper towel or a napkin, and stick it in the stinger of your exhaust pipe. You then pull on the pull-starter a couple of time to prime your engine, and then you remove the paper towel or napkin from your sting after the engine is primed. You then hook up the glow starter and then pull-start your engine to get it going.
