RCU Forums - View Single Post - building a profile need help...
Old 04-30-2005 | 02:51 PM
majortom-RCU
My Feedback: (40)
Default RE: building a profile need help...
Hey xoon, that's a fine looking model. I'm sure you'll have a great time flying it.
One little thing I would mention, I notice you have the adjustable arms on your servos. I have used these in the past on control surfaces, and never had a problem with them. However I was informed that these are intended to be used on throttle servos only--light loads, not control surfaces. So I got with the program, and now use the solid arms for all control surfaces. As you get into bigger models, more power, heavier servo loads, etc. the issue becomes more important. They are a convenient way to adjust your throws, but not as convenient as the adjustable travel settings on digital transmitters.
Anyway, not to quibble, you should be proud of a good piece of work. Have a blast with it!
