AFPD and Calibrate with a Futaba 9C.
Hi
I love AFPD or at least the limited amount of use I have had.
I have a Futaba 9C hooked up to the USB interface. I have found that I can calibrate and use AFPD IF I do NOT touch the metal part of the Tx.
If I touch the metal part the controls jump all over the place.
I believe I have the latest drivers and the updated cable. The cable has cable ties under the shrinkwrap and a plastic section at the pin end where the case screws on.
HELP. What do I do now? Is there a fix?
Jeff
