RE: Great Planes PT- 17 Stearman ARF
Mine is almost done..Ironing out the wrinkles now..you're right in saying, it has a ton of wrinkles..using a Magnum 120 4 stroke..I had 3 cylinders that were broken..returned it to where I purchased the kit (LHS), and got a new about 4 days later..Only I problem I've had is the eleavtor servo..It's buzzing most of the time when I apply elavator..I used the hinges from the kit,but have cut the elavator lose,and installed Robarts large horny points ones...servo dosen't buzz as much as it did before...am using a HS-645mg,at 6v battery,,,going to install a HS-945mg, at 6v and see what happens......will let you know what happens...good luck in building it...
