My DA-50 with tuned pipe is turning an MSC 22x8 around 6950 RPM's. About 1/2 gallon through her.
BTW: I learnt today that if your plane restraint is a heli starting shaft stuck into the ground and nylon straps, you better hold onto the plane. At WOT, the DA almost pulled the damn thing out of the ground
