RCU Forums - View Single Post - How to sheet a built up wing
Old 05-06-2005 | 05:08 PM
PA44Capt
Default How to sheet a built up wing
I have an extra 300 that has a built up wing that is sheeted from the spar forward but has open bays behind the spar. I much preferr the look of sheeted wings when they're all finished. Can I simply take 1/16" ply and cover the wing on both sides? If so, what is the best method for making the curve around the leading edge? Would the best method simply be to soak a portion of ply and bend it around the curve? Thanks for your suggestions.
