RE: Removing Anodizing
Easy-off is the easiest way to remove that stuff other wise you'll be sanding till your fingers fall off.......it can be a mess though....to keep it clean if you have an orbital sander w/120 grit paper that works well to with less of a mess, just sand it right off.....if you go the ez-off way then spray it on....let it sit for 15 min then wipe with a damp sponge....then sanding by hand is a breeze. Just don't get this stuff on anything else because it will stain the hell out of it..... Hope this helps
Shawn
