RCU Forums - View Single Post - Prop Washer Size and Weight
Old 05-14-2005 | 09:16 AM
Blade47's Avatar
Blade47
Default Prop Washer Size and Weight
I was down in my shop this morning getting things ready to go flying when I decided to change out the prop. Found that I need a different size washer to fit on the shaft so that the spinner would fit. Hmmmm went thought all washers that I had and did not find what I need.....
Hmmmm now what to do..... so... sitting there and pondering the lint in my navel I looked upon my wall to see some old used MAS props ...[X(].... What if I cut the tips of ??? the center hole is the same as the shaft?? and because it plastic I can shave it to what ever size I need.... and the weight difference between a metal washer and plastic has got to be good as well...
you got it .... I now have a perfect fit and light weight washer after 15 minutes of work ....and ...put the old prop to some use as well.
let me know what you think ...there must be other Pros and Cons
