RE: Extreme Flight 87" Yak 54 - Build & Fly
After seeing the pics I remembered clearly what I did there. I started off by sanding the pins, but only to rough them up for better glue adhesion. Then I literally forced the pin over to line up with the inner rib hole, tapped the pin in with a small hammer just enough to go through and just used CA to glue it in...it ain't goin' anywhere.
