RCU Forums - View Single Post - BME 44 Unstable Idle Setting
Old 05-23-2005 | 12:59 PM
WRK
Default RE: BME 44 Unstable Idle Setting
With a good servo and proper linkage you should not have to use the engine idle stop screw, if using the screw does help it is an indication that something in the servo/linkage is not always returning to the same position, it is always nice to be able to stop the engine by moving the idle trim lever to full down position in my opinion.
