RE: Hitech 5645mg fails during installation
Yes, that will be standard practice going forward for sure.
As stated before thankfully this manifested itself during setup as this would have certaintly brought down the plane if it happened in the air.
One last note to this; I ran the servo agian before packaging to return to Hitec on a 4.8 volt battery instead of 6 and a standard Futaba RX instead of a PCM, low and behold after 15-20 minutes, same results, servo moing all around by itself.
