RE: Extreme Flight 87" Yak 54 - Build & Fly
Agreed. Choke servo is not only more of a pain to install, but it also may not do you any good in the event of a RX failure, not that that would matter too much, but an out of control plane that goes in deadstick is likely to be a less costly crash. You have this feature with the Smartfly opti switch - if you have no rx signal, you have no engine.
