Big Problem (ram 500)
I have a RAM 500. The problem i have is that i am hitting 150k rpm at 1/8 throttle. I have learned and relearned the ECU. It will also go beyond 150k rpm if i move the stick more than 1/8th. I thought the RPM sensor would stop the turbine if you go beyond 150k ( 150k is my high rpm limit). Also what is the diff between a ram 500 pump and a 750 pump if any?
Chris
