RE: Big Problem (ram 500)
i have 2 pumps. One has a circut board on the back and the other does not. I also checked the edt and i dont think it shows pump pulse width when running. If there is a way to show it i will check it out. I really should call RTI but i feel their time is money and im waisting their time. Im leaning towards the pump as the issue but the other question is , I thought the RPM sensor would shut the turbine down is over the set limit. I know it works below the limit. Run-RMP- Low was my last shutdown. :^)
Chris
