ORIGINAL: turbo4
Here is a direct quote from the DA 50 owners manual........"isolate the charge circuit from the ignition while charging the batteries." Does this mean don't charge the batteries through a charge jack built into a switch? Would the switch in the off position be the "isolation"
Thanks, Joel
If you have the JR JRPA004 charge switch then yes, if it is another manufactures switch I'm of no help.
