RE: Kyosho Twin Storm 800 ROCKS!!
I ran mine for the first time today and it was a bit windy and a tiny bit choppy but it still went through with no problem. Even when you go back over its own wake it doesnt seem effected by it. Although i have an issue with the water cooling. When i blow through it, it barely go through. I can just push some air through it. So i doubt that it could push water through it. And i was sort of right. When its running a drip comes out about every three seconds, i thought a generous stream would come it. So i took of the pipes at certain sections and found that the esc is the bit it has trouble getting through. So later i think ill take it out and see if anything is jammed in it. Have any of you guys had this problem. And after id finished running it, the water that come out of the hole cause i was blowing it was relatively hot around 85 degrees celsius.
So do any of you know what to do or if this is normal?
