RE: YS 120NC bubbles in fuel line
Thanks Dave! I removed the throttle plate and found that the hole was only 1/16, so I opened it up to 1/8 and will try it. Will this help the fuel coming from the carb also? The regulator screw should be flush with the body (approx) correct? Also I noticed that the regulator screw is really easy to turn, like I can do it with my fingertip. Is this okay?
Thanks again
Todd
