RCU Forums - View Single Post - Su-27 L.E. flaps
Old 06-23-2005 | 06:05 PM
  #38
wsmalley
Default RE: Su-27 L.E. flaps
Since my flaps were not designed into the wing, I opted for the bottom hinge location with some lithoplate strips on top to cover the gap with flaps down. I use a dressmaker's tracing wheel to make rivots from the reverse side. It actually adds quite a bit of rigidity. In the 'up' position, the strips slide over the covering and barely raise the surface. Note the gap created on the root side with the flap down. This is why the full size has a circular taper built in. I can cure this with some work but note it's presence. I'll study your new sytem, agreed lessoning the workload is important. The full size has a computer to do this.
ID:	288931   Click image for larger version
ID:	288932   Click image for larger version
