RE: Just ordered a frontier 40...
Well, different weather conditions cause different effects on Monokote, my advice is that you re-seal the trim scheme with a sealing iron, if you don't feel confortable ironing your model then ask an experienced modeler for help. He will use heat to re-activate the glue in the monokote and make it stick better to the wood.
Good luck
Joseph
