http://www2.towerhobbies.com/cgi-bin...?&I=LXR938&P=7
There you go. I finished mine tonight and will try it out tomorrow. I added two extra battery packs (for weight only) in the tail and could only get the CG up to about 8". The manual says CG should be 8.5-9". I will try and see. I hate adding weight! It came out really nose heavy having built it by the book . One exception is that I did not put the throttle servo in the tail, but that is not very much weight anyway using an HS85 mini servo. I will post a pic in my gallery of the arrangement of servos, etc. Good Luck.
EDIT: I posted some more pics in my gallery of the servo layout I chose. Pics are worth a thousabd words on this airplane! You have to be pretty creative to avoid 9 extentions!
