RCU Forums - View Single Post - GP giles 202
Thread: GP giles 202
Old 10-13-2002 | 02:25 PM
basmntdweller
My Feedback: (9)
Default GP giles 202
I fly one with the 160 and a bisson pitts muffler. Choice of props makes a big difference in performance. I prefer the plain master airscrew wood 18-6 for 3D and a top-flite 18-10 for pattern style flying. I would mount the landing gear backwards. You'll need to drill new holes but the ground handling is much better on both grass and asphalt. I added 6oz to the tail to get mine where I like it. Set your low rates and CG per the manual and you won't have trouble with tip stalls. Actually, the manual is wrong on the elevator if I remember correctly. It gives different up and down settings. The corrects settings are on the GP website. Good servos do make a difference. I'm using a couple hitec digitals on the ailerons, 9202s on the elevators and the rudder is a Futaba with about 130 in/oz torque. I tend to forget all the servo numbers. I originally had some of the low end tower servos on it and the upgrade was well worth the cost.
If I can think of any thing else I'll let you know.
Later,,,basmntdweller
