RCU Forums - View Single Post - Barrel Roll
Thread: Barrel Roll
Old 10-17-2002 | 03:02 AM
BernieG
Default Barrel Roll
Originally posted by Bax
Acually, there are several versions of the maneuver known as the "Barrel Roll".
One version, sometimes called the "Civilian" version, has the plane pull up, hold elevator while adding ailerons, and the exit heading is 90 degrees from the entry heading.
There's the "Navy" version, which has the plane follow a spiral path through the air, like the path of a stretched out spring. The exit heading is the same as the entry heading, but displaced to the side on a parallel track.
A third version, sometimes called the "Air Corps" or "Air Force" version has the airplane rolling about a point somewhere outboard of the wingtip. The entry and exit heading are the same, and the exit track would be an extension of the entry track.
The "Civilian" version is the easiest, but looks the worst.
Sorry, i clicked too fast.
Well, I don't care much about versions and sub-versions. What I described is the original "Tonneau Barrique", as done and described by World war one french aces, then translated word for word in english. If you refer to the first US writings about aerobatics, they use french words for everything, and that's because they learned first from there.... What DEFINE a barrel roll, is a ONE G figure. I doubt anything different that what I described could be done at a constant ONE G !
One G means that, even while inverted, you can stand up in the plane and not fall. A NOT coordinated roll would have as result that you would fall on the roof !
Bernard
