RCU Forums - View Single Post - U-Can-Do as a beginner aircraft?
Old 07-14-2005 | 05:32 PM
  #32
MikeEast's Avatar
MikeEast
Default RE: U-Can-Do as a beginner aircraft?
I have had 3 U CAN DOs.
YES, the U CAN DO can be used as a trainer IF you learn from a good solid trainer on a buddy box. If you go it alone you are dead for sure. But if you can pass a standard solo test sortof like what Bubba Gates suggested on the buddy box without getting disoriented or confused then the UCD is great. On a buddy box a UCD is fine, its even good to solo with, if IF you thoroughly learn to fly before you try to solo.
