ORIGINAL: cumn thru
Lee, on the servo arm I would use nothing but 4/40 ball links. Thats what they are set up for. The hole is actually sized for the bolt that goes through the link. Also check out the pull/pull adjustment rig for the wire. You could get away with clevises on the tail end. Good luck, Joe
I see,, Thanks JOE
