RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
is the first one unrepairable. fuse looks ok firewall unattached and rt wing damage. i bet you could fix it. If you loose power keep nose down and belly in do not drop gear or flap. less damage. that rough plowed field probably did more damage than if it was grass. good luck on the new build
TIM
