RE: Cold Duck - Build
The four wing skins are glued and cut to rough shape. Three 4”X1/16” sheets are butt joined using Titebond glue to form the wing skin. Like the original the cores are cut to wrap the skin around the leading edge, but I’ll be sanding 3/16" off the front wing edge so I can use a ¼” balsa cap on the front edge of the wing.
The process of building this aircraft from plans is so easy!
