RE: VMAR Improving?
Hi,
I have a VMar 21Mig also, just bought it, after reviewing the set up book and fitting the vertical stab I noticed that it is very difficlut to get the printed throws of one inch left and right. Did you have the same problem? Does the control wire - rod that is installed in the rudder come lose on yours and did the rod when the rudder is moved left-right, when holding the rudder in your hand, move off center causing the drag when installed in the fuse? Any sugestions?
Bob
