RE: who is the youngest HELICOPTER flyer?
Corey,
Batteries that hot clearly indicates a problem.
At the very least, you will destroy the capacity of the battery pack. Likely, you will see additional problems with your electronics, if they cannot handle the very high current demands that are aparently being pulled from your battery.
What battery are you using? (type, capacity and number of cells)
Are you using the stock mixing board?
Does the motor get hot as well?
Vince
