RE: IF YOU HAD 150.00 TO SPEND, WHICH HELI WOULD YOU GET?
Bullseye, congrats on your decision to go with the 9C. Are you getting the 9CH so that you get the smooth throttle rather than the ratchetty feel that the 9CA has? If you already have ordered the 9CA, don't worry, it is easy to open the case and modify the spring system that causes the ratchets. this makes hovering easier.
On the heli, what are you looking to get into? Indoor electric? Outdoor electric? Nitro?
What equipment do you have?
What are the chances of opening up your budget a bit?
