RCU Forums - View Single Post - beginner plane
Old 07-28-2005 | 01:52 PM
louis3099
Default RE: beginner plane
thanks....
looks like tower has them...now if I get one under the needed things it doesnt mention a rx? which one would I need? I'm assuming a micro one.
http://www2.towerhobbies.com/cgi-bin...&I=LXHCJ2&P=RF
FEATURES: Fuselage: Aluminum channel
Wings: One-piece foam construction
Landing gear: Pre-bent one piece wire with two 76.2mm diameter wheels
and one 25.4mm diameter tail wheel and tail skid wire.
Hardware: All necessary hardware included
Motor and gearbox with preinstalled plastic mount
Can be constructed with a removable tail also as a glider
Warranty: GWS guarantees this kit to be free from defects in both
materials and workmanship at the date of purchase
INCLUDES: Aluminum fuselage channel,EPS-400C motor system.EP-7035 prop
main landing gear,tail skid wire,main wheels(76.2mm),tail wheel
(25.4mm),spinner,glue,rubber bands,all necessary hardware and
photo-illustrated instructions,
REQUIRES: Speed Control: Or auto-cut-off
Battery: 2/3 AA cells 270-400mah or AA cells 600mah 7.2V
Charger: Timed or peak for 2/3 AA cells
Radio: 2-4 Channel
Servos: 2 Naro,Micro,or Mini servos
(1-elevator, 1-rudder)
Misc. Items: Building and field equipment
Required for removable tail units in addition to the above is a
electric drill,hacksaw and 1mm drill bit.
