RCU Forums - View Single Post - ignition battery interference
Old 07-31-2005 | 04:15 PM
RTK's Avatar
RTK
Default RE: ignition battery interference
This is the way I look at it. Do a ground check engine off, then do a ground check engine on. If you have more than 10-15% degradation you might have a problem. Be sure to always meet or exceed the manufacturers minimum distance with engine on.
