RE: Showtime
OAK,
I notice on my showtime that the pull-pull wires for the rudder will have a lot of slop when the rudder is deflected, but it is tight when neutral. Is this normal with pull-pull setup?
If your pull-pull does this it isn't setup right. The distance between the cable attach points at the servo must be the same as the distance between cable attach point on rudder horn.
