RCU Forums - View Single Post - Needle valve to Carb fuel line arch...
Old 08-05-2005 | 11:38 AM
Flypaper 2
Default RE: Needle valve to Carb fuel line arch...
I tend to disagree with the delay in throttle, due to hydraulics. If I go to the basement, close a valve 25 ft. away from the sink. Open the valve at the sink, nothing will run out. Go back and open the other valve 25 ft, away, water will flow as soon as you open the valve. Water at the valve is pushing a solid column of water from valve to sink.
