RE: Help! Newbie here
with a higher voltage, if you are using the same prop, you will draw significantly more current. this means higher load on the battery, and may trigger the auto cutoff prematurely because the voltage under the heavy load is so low. reduce your prop size a little bit and see if it helps.
-Clam
