RE: Sig Something Extra Kit
Tychoc:
I have two questions for you - 1)what type of landing gear did you go with? The dubro?
2)also, what engine did you use?
I am wondering if there will be enough clearance of the prop if I use the dubro landing gear. I want to put a 4-stroke in it.
I have one more question, do the instructions say sheet the turtle deck. If not, what type of wood sheet did you use and did you have to do mods to the fuselage?
I have been using med CA, do you think that will weight down the wings. I have been mainly using wood glue, but sometimes I have used Med CA to speed up the building time.
