RE: Starting a heli with a drill instead of a normal starter
I've never seen (not that it doesnt exist, i've just never seen one) a hex shaft that will fit in a drill with a 1 way bearing.
If you don't have the one way you really should consider a standard starter w/ a wand and bearing.
You run the risk of tearing something up otherwise.
