RCU Forums - View Single Post - Need help again... Pro 540 question
Old 08-11-2005 | 07:39 PM
PHILB571's Avatar
PHILB571
Default RE: Need help again... Pro 540 question
John,
Unfortunatly i dont, but, the mount for the edge has the the mounting holes and the shaft hole below the thrust line. should that be?and i should cut out for that? i want to mount the motor behind the mount. its almost like if the measurements were off by 1/4 - 1/2 inch all the way around the mount. as of right now, i would have to shave donw the nose area to make the mount fit. let me make sure i have the right mount here. from laft to right or the width of the mount is 3" hight or top to bottom is 2" longer on the bottom side shorter on the top. is the correct.
phil
