RCU Forums - View Single Post - Dragonfly V problems
Old 08-17-2005 | 11:26 PM
macsense
Default RE: Dragonfly V problems
Before switching on the heli power, make sure your throttle stick is on the lowest point, and when you switched-on the heli, try waiting for at least 15 seconds before flight. But the main culprit may well be the battery itself. Try discharging & charging it several times, then charge it up fully & fly. If problem persists, bring back the heli to where you bought it, get them to check.
