ORIGINAL: wgeffon
Mark!
Where the F have you been? We havent seen you at any IMAC's this year. Dont say your busy at work cause I know better.
I dont know if this has been mentioned before but, the large black and red connectors that DA has on their ingnition need to be changed to something else before you fly. The problem with them is that there is no support inside the connectors for the pins and they break from vibration. CHassan, maybe thats soemthing to check if you are still using that connector.
Yeah Culpepper, where you been?????????????
Wayne, I have never changed mine and never had one come loose. In fact, I have never heard of that happening till you mentioned it. What are you using, maybe I will change mine. My DA100 has 3 years and over 100 gallons thru it on the original stuff from DA. I might be pressing my luck here. Clue me in.
Jeff W.
