Help me set up a mix please!
I'm using a futaba 9cA super
Ok, I have a wing with 4 servos each with their own surface. I need the outer two to act as ailerons and the inner two to be flaperons when a switch..(A for example) is UP. Then,..I need the outer two to not function at all, and the inner two to be regular ailerons when the switch is in the down position.
I know this is a very strange setup, but it is what I need.
