ORIGINAL: romanrc
Single two problems cost work to me to clear the cabin and the cable
of pull pull becomes loose with the 2 or 3 fligths. can help me please?
Sorry for my English
Greetings
romanrc, you can use the cable system that is included. Here is a trick to help them stay in those housings. Take the cable and tie a single slip knot and leave about 1/4" excess, stuff down into the housing and then screw it onto the rigging coupler. You can do this on both ends, it will take some measuring to get the overall length, be sure to leave yourself enough so you are not short and you can tighten to your desired rigidity.
Jeff Williams
