RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 08-30-2005 | 07:33 PM
  #1185
Sturtz's Avatar
Sturtz
My Feedback: (20)
Default RE: Vectorflight Edge 540 build
First,, you guys with the 2stroke 91s ,,, tell me how the plane flys with this setup. I have an OS.91FX I was thinking of swapping with my Saito on the Edge since it will be down for a short while. VectorFlight says it will only be a week or so till they can ship me the replacement parts.
Programing the 7Cap for duel channel alerons. I'll try my best to explain this . Have patience. lol
The left aileron (standing behind the plane) will be on channel 1. The right aileron will be on channel 6.
Ok,, first go into the secondary programing and activate your Flaperons.( Must read as "On". I have channel 6 set to the Aileron-2 function. This ties your two ailerons together as one. You may need to reverse the servos to have them move correctly. Leave the Differential alone for now.
Next,, go to flap trim and activate it. This will de-activate your flap trim knob on the radio. Again, leave the trims at zero.
Go back into the first stage programing and choose the Sub Trim menu. After getting the left aileron set where it needs to be use the sub trim again for channel 6 and match your ailerons up. Make sure the end point adjustments are the same on each so you'll get a smooth roll rate.
If you have any other questions or trouble with it I'd be glad to help you over the phone if needed.
Let me know how the programing comes out for ya.[8D]
