RCU Forums - View Single Post - Showtime
Thread: Showtime
Old 09-04-2005 | 06:21 PM
  #827
Big Barry's Avatar
Big Barry
Default RE: Showtime
I wish it was my elevator, but that would be too easy. I'm seriouse for you guys that have had to use alot of left aileron trim, use some spoileron so that when you are at full elevator your aileron is at least in line with the wing and not below. You can use as much up as you like, if you like a lot so that it waterfalls real tight you can mix it in. I only set it to stop dropping the wing on HAOA. This is not for the good flying Showtimes only for the ones that want to drop a wing in certain maneuvers. So if you are happy with your Showtime great, if not, you might want to try to mix in some spoileron.
